powerlogix
Stichworte: -
Zitat von johndoe1 Beitrag anzeigenAttached Files
1,8ghz sonnet? 300 us$. bei uns kostet es sicher 300 euro...
die kleineren cpus mit größerem cache sind ja leider nicht mehr erhältlich.
powerlogix ist auch interessant:
A Better Solution for Power
When the challenge of meeting the power requirements of the next generation G4 Cube processor upgrades was first approached, it was expected that a new, higher power VRM module would be provided to replace the Apple stock VRM.
The Apple Cube VRM happens to be a relatively complicated device which takes the single 28v power in and converts it to the three different voltages required by the system. While a new VRM can solve the processor power requirement issue, it still is dependent on a power distribution pathway which Apple did not necessarily design for the higher power load. Further, this VRM would likely generate more heat and adding to that, would be larger and interfere with the internal airflow of the Cube.
A note about airflow: The Power Mac G4 Cube utilizes a natural convection cooling design. However, that is not enough to keep an ugpraded Cube cool (or a factory stock Cube, as many owners have found out over the years). A fan was designed to be installed into the chassis of the Cube, but it was decided at the last minute to not include it. There is even a power plug built into the unit to plug this missing fan into. We ship a low noise fan with this upgrade to keep everything as cool as possible, because heat can and will cause component failure prematurely. This is cheap insurance for your investment.
Sometimes it's the simple solutions that are the best - this is one of those times. The great minds at PowerLogix realized that rather than needing to replace the three voltage Apple VRM module, a single voltage VRM could be utilized right on the processor upgrade board! This solution completely bypasses the Apple VRM (which results in it running cooler) and gets clean, correct power straight to each processor through separate and independent onboard power supplies. It's a better way to power the Cube Processor upgrades with less complication and cost as well.
The PowerForce47 Cube upgrade is the 2nd upgrade in the PowerLogix line to feature the PowerLogix Cube VRM Bypass Technology, the right solution to meet the needs of today's higher speed and higher power requiring single and dual processor upgrades that also takes a load off the Apple VRM at the same time.
wie regelt sonnet die stromversorgung?
ein benchmark zwischen dem sonnet 1,8ghz ohne l3 cache und dem 1,4ghz mit 2mb l3 cache wäre interessant.
für einen cube + cpu-upgrade bekommt man ja schon einen intel-mini!Last edited by johndoe1; 20.07.2008, 14:32.
Zitat von johndoe1 Beitrag anzeigen... für einen cube + cpu-upgrade bekommt man ja schon einen intel-mini!
In meinem Fall kann ich jedoch sagen: "... den Cube hab' ich ja schon!"
den suche ich ja auch noch...
aber an einem mini kann man nicht so schön basteln...
übrigens sollen 1,8ghz wegen dem 100er bus nicht viel schneller sein als 1,4 bis 1,5ghz mit l3 cache. ein kleiner unterschied sind auch die von sonnet angebotene 7447 cpu und die neuere 7448 cpu von powerlogix.
wenn es den 1,4ghz mit l3 noch geben würde... der beachball ist doch schon sehr nervig.
oder eben ein händler für den 1,7ghz powerlogix.
Beim Mini beschränkt sich die "Bastelei" eben auf den HD-, Prozessor- und RAM-Tausch ... und das war's ... stimmt schon. Aber der Prozessor-Tausch ist schon 'ne "spannende" Sache!
machen möchte ich es auf jeden fall mal.
beim "normalen" power mac g4 sind es ja nur 2 clips, 3 schrauben (beispiel quicksilver) und dann hält man die karte in der hand.
beim cube ist es schon etwas umfangreicher.
powerlogix liefert neben einer bebilderten anleitung sogar noch einen film mit.
der einzige haken ist und bleibt der einbau eines lüfters...
Zitat von spaceballs Beitrag anzeigenEDIT: Hmmm ... und wenn ich doch mal irgendwann "Leo" installieren will?!
...ist sicher nur die alte beschreibung. laut sonnettech.com sind die encore 1,8ghz upgrades voll os x kompatibel.
Supports Mac OS X Version 10.5.x, 10.4, 10.3.5+, and Mac OS 9.2
Zitat von spaceballs Beitrag anzeigenEDIT: Hmmm ... und wenn ich doch mal irgendwann "Leo" installieren will?! Mac Mini for work
iPad Pro for work outside
beautifulfor life
Zitat von Cube Beitrag anzeigenUnd außerdem läuft Leo auch unter 867 MHz.... Install halt per Target-Modus
nur ganz kurz, bevor's auf die Bowlingbahn geht :bliny: :
meine Bedenken galten nicht der CPU-Frequenz, sondern generell, daß das Upgrade evtl. mit Leo nicht "klar kommt" - egal ob Target- oder "Normal-Installation". :bliny:
Und Tschüß ...
bei den cpus brauchst du keine bedenken haben.wenn der schneeleopold kommt ist es eh vorbei mit ppc.
es kann sein das die grafikkarte probleme macht - darum gibts spezielle roms bei the macelite für verwendung unter leopold.
