Seit Vorgestern gibt es ein größeres Update des TOR Browsers auf Version 4.5 (Basis Firefox 31.6.0)!
Auf dem Mac läuft TOR nur noch auf 64-bit Rechnern , weiterhin wurde das Folgende geändert:
Here is the complete list of changes in the 4.5 series since 4.0:
All Platforms
Update Tor to 0.2.6.7 with additional patches:
Bug 15482: Reset timestamp_dirty each time a SOCKSAuth circuit is used
Update NoScript to 2.6.9.22
Update HTTPS-Everywhere to 5.0.3
Bug 15689: Resume building HTTPS-Everywhere from git tags
Update meek to 0.17
Include obfs4proxy 0.0.5
Use obfs4proxy for obfs2, obfs3, obfs4, and ScrambleSuit bridges
Pluggable Transport Dependency Updates:
Bug 15265: Switch go.net repo to golang.org/x/net
Bug 15448: Use golang 1.4.2 for meek and obs4proxy
Update Tor Launcher to 0.2.7.4. Changes since 0.2.7.0.2 in 4.0.8:
Bug 11879: Stop bootstrap if Cancel or Open Settings is clicked
Bug 13271: Display Bridge Configuration wizard pane before Proxy pane
Bug 13576: Don't strip "bridge" from the middle of bridge lines
Bug 13983: Directory search path fix for Tor Messanger+TorBirdy
Bug 14122: Hide logo if TOR_HIDE_BROWSER_LOGO set
Bug 14336: Fix navigation button display issues on some wizard panes
Bug 15657: Display the host:port of any connection faiures in bootstrap
Bug 15704: Do not enable network if wizard is opened
Update Torbutton to 1.9.2.2. Changes since 1.7.0.2 in 4.0.8:
Bug 3455: Use SOCKS user+pass to isolate all requests from the same url domain
Bug 5698: Use "Tor Browser" branding in "About Tor Browser" dialog
Bug 7255: Warn users about maximizing windows
Bug 8400: Prompt for restart if disk records are enabled/disabled.
Bug 8641: Create browser UI to indicate current tab's Tor circuit IPs
(Many Circuit UI issues were fixed during 4.5; see release changelogs for those).
Bug 9387: Security Slider 1.0
Include descriptions and tooltip hints for security levels
Notify users that the security slider exists
Make use of new SVG, jar, and MathML prefs
Bug 9442: Add New Circuit button to Torbutton menu
Bug 9906: Warn users before closing all windows and performing new identity.
Bug 10216: Add a pref to disable the local tor control port test
Bug 10280: Strings and pref for preventing plugin initialization.
Bug 11175: Remove "About Torbutton" from onion menu.
Bug 11236: Don't set omnibox order in Torbutton (to prevent translation)
Bug 11449: Fix new identity error if NoScript is not enabled
Bug 13019: Change locale spoofing pref to boolean
Bug 13079: Option to skip control port verification
Bug 13406: Stop directing users to download-easy.html.en on update
Bug 13650: Clip initial window height to 1000px
Bugs 13751+13900: Remove SafeCache cache isolation code in favor of C++ patch
Bug 13766: Set a 10 minute circuit lifespan for non-content requests
Bug 13835: Option to change default Tor Browser homepage
Bug 13998: Handle changes in NoScript 2.6.9.8+
Bug 14100: Option to hide NetworkSettings menuitem
Bug 14392: Don't steal input focus in about:tor search box
Bug 14429: Provide automatic window resizing, but disable for now
Bug 14448: Restore Torbutton menu operation on non-English localizations
Bug 14490: Use Disconnect search in about:tor search box
Bug 14630: Hide Torbutton's proxy settings tab.
Bug 14631: Improve profile access error msgs (strings for translation).
Bugs 14632+15334: Display Cookie Protections only if disk records are enabled
Bug 15085: Fix about:tor RTL text alignment problems
Bug 15460: Ensure FTP urls use content-window circuit isolation
Bug 15502: Wipe blob: URIs on New Identity
Bug 15533: Restore default security level when restoring defaults
Bug 15562: Bind SharedWorkers to thirdparty pref
Bug 3455: Patch Firefox SOCKS and proxy filters to allow user+pass isolation
Bug 4100: Raise HTTP Keep-Alive back to 115 second default
Bug 5698: Fix branding in "About Torbrowser" window
Bug 10280: Don't load any plugins into the address space by default
Bug 11236: Fix omnibox order for non-English builds
Also remove Amazon, eBay and bing; add Youtube and Twitter
Bug 11955: Backport HTTPS Certificate Pinning patches from Firefox 32
Bug 12430: Provide a preference to disable remote jar: urls
Bugs 12827+15794: Create preference to disable SVG images (for security slider)
Bug 13019: Prevent Javascript from leaking system locale
Bug 13379: Sign our MAR update files
Bug 13439: No canvas prompt for content callers
Bug 13548: Create preference to disable MathML (for security slider)
Bug 13586: Make meek use TLS session tickets (to look like stock Firefox).
Bug 13684: Backport Mozilla bug #1066190 (pinning issue fixed in Firefox 33)
Bug 13788: Fix broken meek in 4.5-alpha series
Bug 13875: Spoof window.devicePixelRatio to avoid DPI fingerprinting
Bug 13900: Remove 3rd party HTTP auth tokens via Firefox patch
Bug 14392: Make about:tor hide itself from the URL bar
Bug 14490: Make Disconnect the default omnibox search engine
Bug 14631: Improve startup error messages for filesystem permissions issues
Bugs 14716+13254: Fix issues with HTTP Auth usage and TLS connection info display
Bug 14937: Hard-code meek and flashproxy node fingerprints
Bug 15029: Don't prompt to include missing plugins
Bug 15406: Only include addons in incremental updates if they actually update
Bug 15411: Remove old (and unused) cacheDomain cache isolation mechanism
Bug 15502: Isolate blob: URI scope to URL domain; block WebWorker access
Bug 15562: Disable Javascript SharedWorkers due to third party tracking
Bug 15757: Disable Mozilla video statistics API extensions
Bug 15758: Disable Device Sensor APIs
Linux
Bug 12468: Only print/write log messages if launched with --debug
Bug 13375: Create a hybrid GUI/desktop/shell launcher wrapper
Bug 13717: Make sure we use the bash shell on Linux
Bug 15672: Provide desktop app registration+unregistration for Linux
Bug 15747: Improve start-tor-browser argument handling
Windows
Bug 3861: Begin signing Tor Browser for Windows the Windows way
Bug 10761: Fix instances of shutdown crashes
Bug 13169: Don't use /dev/random on Windows for SSP
Bug 14688: Create shortcuts to desktop and start menu by default (optional)
Bug 15201: Disable 'runas Administrator' codepaths in updater
Bug 15539: Make installer exe signatures reproducibly removable
Mac
Bug 10138: Switch to 64bit builds for MacOS
All Platforms
Update meek to 0.17
Linux
Windows
Mac
