Nightshift Mode ab 10.12.4
Alt 06.02.2017, 18:07   #1
Standard Nightshift Mode ab 10.12.4
Leider sind ja nur bestimmte Mac´s supported - es sei denn....
Lest selbst:
Supported Mac models for Night Shift in Sierra 10.12.4
Night Shift was introduced in macOS Sierra 10.12.4 (Build 16E144f and Public Beta-1) and it is controlled by CoreBrightness.framework and supported by the following Mac models:
MacBookPro9,x
iMac13,x
Macmini6,x
MacBookAir5,x
MacPro6,x
MacBook8,x
Apple did not release any information about this. Not just yet, but I know this because I located the checks for this in this framework, and there it checks for matching Mac model names:
MacBookPro
iMac
Macmini
MacBookAir
MacPro
MacBook
Night Shift however is not supported by all Mac models. Nope. There is a list with minimum requirements, which I looked up with help of:
nm /S*/L*/PrivateFrameworks/CoreBrightness.framework/CoreBrightness|grep _ModelMinVersion
000000000001d490 S _ModelMinVersion
Ok. Now we know the offset. Time to dump the data with help of:
xxd -s 0x1D490 -l 24 /S*/L*/PrivateFrameworks/CoreBrightness.framework/CoreBrightness
0001d490: 0900 0000 0d00 0000 0600 0000 0500 0000
0001d4a0: 0600 0000 0800 0000
09 = MacBookPro9,x
0d = iMac13,x
06 = Macmini6,x
05 = MacBookAir5,x
06 = MacPro6,x
08 = MacBook8,x
Now you know how I did it, and in case you happen to own a Mac model that isn’t supported, yet, then you could try to patch the matching value in CoreBrightness.framework. The colors that I used should help you to find the correct spot.
Anyway. This my friends is how it is done. Have fun now.
Edit: The order of the MacBookPro and iMac was wrong – see comments. Fixed thanks to the heads up from Thomas and Nicolinux.
Update: You need to re-sign the patched framework binary with:
sudo codesign -f -s - /S*/L*/PrivateFrameworks/CoreBrightness.framework/Versions/Current/CoreBrightness
Note: You may only use this patch in your software if the source code is available, you are not asking for donations, and clearly state that this was my work. Thank you.
Damit sollte Nightshift auch bei älteren Modell funktionieren.
Diese 3 User sagen Acid Burn danke für seinen Beitrag:
Alt 07.02.2017, 09:41   #2
Und fr den Fall, dass es nicht klappt: Den Rechner einfach ausschalten und ins Bett gehen, wenn die Augen schmerzen.
Diese 2 User sagen Paulchen danke für seinen Beitrag:
Alt 07.02.2017, 10:07   #3
Lest selbst:
MacBookPro9,x
iMac13,x
Macmini6,x
MacBookAir5,x
MacPro6,x
MacBook8,x
Da ich ja 2 Books habe, die offiziell unterstützt werden, kann ich es mir dort erst 'mal angucken, ohne mich auf es sei denn stürzen zu müssen...
Aber halt, vielleicht sollte ich überhaupt erst 'mal einen Rechner auf 10.12.x upgraden...
Alt 07.02.2017, 16:25   #4
Ja, dass solltest du wohl tun
Alt 07.02.2017, 16:42   #5
Bisher habe ich aber noch keinerlei Gründe dafür gesehen, das war früher doch ganz anders...
Alt 07.02.2017, 16:56   #6
Denke an die etlichen Sicherheitslücken die geschlossen wurden....
Alt 07.02.2017, 17:00   #7
Sicherheitsupdates gibt es auch für die Vorgängerversionen noch...
Alt 07.02.2017, 17:16   #8
Dann bleibe halt bei "deiner " Yosi
Alt 08.02.2017, 13:46   #9
Eine Yosi und mehrere EC habe ich im Einsatz!
Alle Zeitangaben in WEZ +2. Es ist jetzt 13:09 Uhr.
