Alt 21.06.2016, 17:01   #111
guilmant
Scheint sogar noch so neu zu sein, dass mein TOR-Browser nichts findet
Alt 21.06.2016, 17:06   #112
Für den TOR Browser gab es heute wieder ein Update auf Version 6.0.2 (Firefox 45.2.0esr)!
Es wurden folgende Änderungen vorgenommen:
Zitat von www.torproject.org
* All Platforms
* Update Torbutton to 1.9.5.5
* Bug 19417: Clear asmjscache
* Bug 19401: Fix broken PDF download button
* Bug 19411: Don't show update icon if a partial update failed
* Bug 19400: Back out GCC bug workaround to avoid asmjs crash
* Windows
* Bug 19348: Adapt to more than one build target on Windows (fixes updates)
* Linux
* Bug 19276: Disable Xrender due to possible performance regressions
Alt 21.06.2016, 17:07   #113
Dem ist so, über meinen Link findest Du aber die neuen Versionen!
Alt 03.08.2016, 10:50   #114
Auch für den TOR Browser gab es seit gestern wieder ein Update auf Version 6.0.3 (Firefox 45.3.0esr)!
Tor Browser 6.0.3 is now available from the Tor Browser Project page and also from our distribution directory.
This release features important security updates to Firefox.
This release updates firefox to 45.3.0esr. Additionally, it bumps NoScript to 2.9.0.12, HTTPS-Everywhere to 5.2.1, disables asmjs, removes meek-google and contains a few other bug fixes.
Note: Due to bug 19410, on OSX the incremental update will not be working for users who installed the previous version using the .dmg file. The internal updater should still work, though, doing a complete update.
Here is the full changelog since 6.0.2:
All Platforms
Update Firefox to 45.3.0esr
Update Torbutton to 1.9.5.6
Bug 19417: Disable asmjs for now
Bug 19689: Use proper parent window for plugin prompt
Update HTTPS-Everywhere to 5.2.1
Update NoScript to 2.9.0.12
Bug 19715: Disable the meek-google pluggable transport option
Bug 19714: Remove mercurius4 obfs4 bridge
Bug 19585: Fix regression test for keyboard layout fingerprinting
Bug 19515: Tor Browser is crashing in graphics code
Bug 18513: Favicon requests can bypass New Identity
OS X
Bug 19269: Icon doesn't appear in Applications folder or Dock
Android
Bug 19484: Avoid compilation error when MOZ_UPDATER is not defined
Alt 17.08.2016, 11:52   #115
Für den TOR Browser gibt es seit gestern ein Sicherheits-Update auf Version 6.0.4 (Firefox 45.3.0esr)!
The full changelog since Tor Browser 6.0.3 is:
All Platforms
Update Tor to 0.2.8.6
Update NoScript to 2.9.0.14
Bug 19890: Disable installation of system addons
Alt 16.09.2016, 15:03   #116
Für den TOR Browser gibt es seit heute ein Update auf Version 6.0.5 (Firefox 45.4.0esr)!
All Platforms
Update Firefox to 45.4.0esr
Update Tor to 0.2.8.7
Update Torbutton to 1.9.5.7
Bug 18589: Clear site security settings during New Identity
Bug 19906: "Maximizing Tor Browser" Notification can exist multiple times
Update HTTPS-Everywhere to 5.2.4
Bug 20092: Rotate ports for default obfs4 bridges
Bug 20040: Add update support for unpacked HTTPS Everywhere
Windows
Bug 19725: Remove old updater files left on disk after upgrade to 6.x
Linux
Android
Bug 19706: Store browser data in the app home directory
Build system
All platforms
Upgrade Go to 1.4.3
Alt 16.11.2016, 13:32   #117
Für den TOR Browser gibt es seit gestern 'mal wieder ein Update auf Version 6.0.6 (Firefox 45.5.0esr)!
All Platforms
Update Firefox to 45.5.0esr
Update Tor to 0.2.8.9
Update OpenSSL to 1.0.1u
Update Torbutton to 1.9.5.12
Bug 20414: Add donation banner on about:tor for 2016 campaign
Translation updates
Update Tor Launcher to 0.2.9.4
Bug 20429: Do not open progress window if tor doesn't get started
Bug 19646: Wrong location for meek browser profile on OS X
Update HTTPS-Everywhere to 5.2.7
Update meek to 0.25
Bug 20030: Shut down meek-http-helper cleanly if built with Go > 1.5.4
Bug 19838: Add dgoulet's bridge and add another one commented out
Bug 20296: Rotate ports again for default obfs4 bridges
Bug 19735: Switch default search engine to DuckDuckGo
Bug 20118: Don't unpack HTTPS Everywhere anymore
Windows
Bug 20342: Add tor-gencert.exe to expert bundle
OS X
Bug 20204: Windows don't drag on macOS Sierra anymore
Bug 20250: Meek fails on macOS Sierra if built with Go < 1.7
Build system
All platforms
Bug 20023: Upgrade Go to 1.7.3
Alt 18.11.2016, 19:01   #118
Wird beim TOR Browser (ich nutze das Teil ja nicht) auch um eine Spende gebeten?
Mozilla scheint da wohl wieder etwas in Geldnöten zu stecken und bittet im Firefox um eine Spende.
Habe das vor einiger Zeit schon mal gemacht und dachte eigentlich, dass es dem Laden wieder gut geht.
Zumindest möchte ich nicht, auch wenn der Chrome Browser angeblich über 2 Milliarden Nutzer haben soll , auf mein geliebten Firefox verzichten.
Alt 18.11.2016, 19:18   #119
Bei mir nicht (FF 50)...
Alt 18.11.2016, 19:29   #120
Hmmm seltsam, Empfänger ist aber die:
Händler
Mozilla Foundation
donate@mozillafoundation.org
650-903-0800
Vielleicht quengeln sie nur bei den Leuten, die schon mal was gegeben haben.
EDIT:
Gerade auf FF 50 aktualisiert, nu isses wech!
Geändert von OlliF (18.11.2016 um 19:40 Uhr).
Alle Zeitangaben in WEZ +2. Es ist jetzt 15:09 Uhr.
